Blower Fan not working on '3'
Barton
Sun Sep 05, 2010 9:08 pm
The blower fan in my e30 isn't quite working correctly
it will work on 1,2, and 4, but there's nothing on 3
i took the switch out and checked that, it works as it should and i checked the connection of the switch to the multiplug it clips into which again is fine
whats the next step? where do the wires go to (are they easy to access the other end to test continuity?)
thanks again
srmalek
Mon Sep 06, 2010 12:05 pm
mine did the same, change the regulator , now work fine
Barton
Mon Sep 06, 2010 5:19 pm
regulator?
SPADGE
Mon Sep 06, 2010 5:31 pm
Barton wrote:regulator?
There is a regulator that fits in the side of the heater box and regulates the speed of the fan.
I have these if you require one @ £12 posted.
Jules..
Barton
Mon Sep 06, 2010 5:42 pm
sorry for all the questions, but is this an easily accessible item?
ProToZyKo
Mon Sep 06, 2010 8:17 pm
Well depends, mine is easy, some is harder, just put your hand up under the steering wheel towards the motor, feel around until you find it ;) Then pull, you should maybe be able to see it, but it's hard, there is some wires going into it. Hard for me to explain ;)
Barton
Mon Sep 06, 2010 8:55 pm
anyone got a pic of what i'm looking for?
ProToZyKo
Tue Sep 07, 2010 7:52 pm
http://e30.bmwdiy.info/blower-resistor/index.html This should help.
On mine i can't take the resistor out from there, i need to do it inside the car, but if you take a look down there you can see what you are looking for.
