When I swapped the E36 rack into my chromie I just bolted the job lot up complete with the E36 inner & outer tie rods.
No dramas with fitting etc.
I've heard a few mention that they fitted the E30 inner & outer tie rods to the E36 rack. Is this actually necessary?
Lee
E36 rack swap, are E30 tie rods needed?
as kilrone said you can use the e36 ones. im using the e36 ones becuase the ones on the rack were ok
BadDave
I used New E30 ones as the ones that came attached to the E36 rack were of unknown age/condition
