Car running rich.... Still stinks!! BREAKING NEWS!!
bedumon
Sat Jul 24, 2010 9:23 pm
So I've had the car taken into to the garage for a full service and a suspension change. I also assumed I had a fuel leak due to the MPG and strong smell of fuel.
After having the work done my mechanic had a look for a fuel leak, however I've been told there is not leak but the car is running too rich (very pungent of smell of petrol out of the exhaust.)
So now what do I have to do/change to get the car running perfect?
Sat Jul 24, 2010 9:28 pm
what engine?
eta
Sat Jul 24, 2010 10:05 pm
Coolant temperature sensor could be at fault., its the same on all E30 engines. It is an NTC thermistor so check with a multimeter in boiling water it should be a lot lower than in cold tap water.
The bentley gives the the following values.
@20 degrees C rsistance = 2000-2900 ohms
@80 degrees C resistance = 300-360 ohms
If its a little outside those values don't worry. It function as an NTC though.
bedumon
Sat Jul 24, 2010 10:15 pm
E30BeemerLad wrote:what engine?
316i
bedumon
Sat Jul 24, 2010 10:16 pm
eta wrote:Coolant temperature sensor could be at fault., its the same on all E30 engines. It is an NTC thermistor so check with a multimeter in boiling water it should be a lot lower than in cold tap water.
If your on about the blue temp sensor, I've changed it.
eta
Sun Jul 25, 2010 9:06 am
So you have done that then. Is it runnning rich at idle or at all throttle positions. There is a hex screw on the AFM which can be opened out to reduce CO and hydrocarbon emmsissons. The AFM could be at fault.
bedumon
Sun Jul 25, 2010 1:05 pm
eta wrote:So you have done that then. Is it runnning rich at idle or at all throttle positions. There is a hex screw on the AFM which can be opened out to reduce CO and hydrocarbon emmsissons. The AFM could be at fault.
I'm not sure but the smell is very strong on start-up. Also it can be smelt strongly when stopped in traffic.
maxfield
Sun Jul 25, 2010 1:17 pm
Has someone changed the fuel pressure regulator...
bedumon
Sun Jul 25, 2010 2:13 pm
maxfield wrote:Has someone changed the fuel pressure regulator...
No idea. What is it and where is it located?
maxfield
Sun Jul 25, 2010 2:15 pm
End of the fuel rail.
Some people put these on to make the car 'faster' all the do is cause your car to overfuel.
Same with the silly eBay resistor.
Sun Jul 25, 2010 3:04 pm
It could be something as simple as leaking fuel pipes. 20 year old fuel hose can be very porous.
bedumon
Sun Jul 25, 2010 6:28 pm
maxfield wrote:End of the fuel rail.
I don't think this would be the case as I purchased the car "very" standard and I have not changed it....but I will check.
Brianmoooore wrote:It could be something as simple as leaking fuel pipes. 20 year old fuel hose can be very porous.
I've changed all the lines and have had them checked. No problems there.
My mechanic has said it could be the distributor cap/AFM. Also when the timing belt was done, the rotary arm was changed. My parts guy told me the rotary arm I had on it was from a 325 and not the standard 316 arm. I changed it like for like so I'm wondering if this could be why the car is running rich?
Sun Jul 25, 2010 9:19 pm
I've no idea what the fine details are of the difference between a M40 rotor arm and a M20 one, but if it causes a misfire, a gas analyser will show the car as running rich, as unburnt fuel will be entering the exhaust system.
Ajsingh
Mon Jul 26, 2010 12:45 am
Id personally adjust the air flow meter and see if it makes a difderance, if not then thats knackered!
Always start at the basics... If the air flows knackered then theres enough air gettin into the engine hence it adjusts by adding more fuel.. Put the car on a CO machine and adjust it
Ajsingh
Mon Jul 26, 2010 12:46 am
Then theres NOT enough air ****
Ajsingh
Mon Jul 26, 2010 12:47 am
octanejunkie
Mon Jul 26, 2010 8:33 am
AFM deffo.
Mon Jul 26, 2010 9:12 am
If the AFM hasn't been miss adjusted before, then it doesn't need adjusting now. You might get an improvement by adjusting it, but you are introducing a second 'fault' to balance out the existing fault. If you do adjust it, carefully note where it is now.
bedumon
Mon Oct 04, 2010 8:25 pm
So I finally changed the AFM to one that I bought of a zoner, but I still seem to have the same problem. MPG way too high and a strong smell. I've noticed that when I turn the heaters on (middle ones!) the smell seems to get alot more potent.
Any ideas guys......I really need to get this sorted as I'm getting heavily intoxicated!
e30mazm3
Mon Oct 04, 2010 8:37 pm
Its no good everybody guessing this and that and you wasting your money. Put it on a gas analyser at an MOT station and write down the values of the:
CO
HC's
CO2
make sure the car is warm when you test it.
Tell us the values
doc323
Fri Oct 08, 2010 9:46 am
Funny that as i have a 316 and has the same problem!! :cry:
Havent look into it yet....as just going to fit my m52 that will solve it! :D
jimjim
Fri Oct 08, 2010 9:54 am
Are you sure that the small rubber fuel pipe thats goes into the fuel rail under the inlet manifold has been changed? It's only a couple of inches long and is hard to spot because of its location. I have a couple of 316/318i's and they have leaked in that same place, and your symptoms seem similar to mine.
Fri Oct 08, 2010 8:17 pm
If the heater fan is sucking a strong fuel smell into the cabin, then you almost certainly have a leak!
bedumon
Wed Oct 20, 2010 11:56 pm
jimjim wrote:Are you sure that the small rubber fuel pipe thats goes into the fuel rail under the inlet manifold has been changed? It's only a couple of inches long and is hard to spot because of its location. I have a couple of 316/318i's and they have leaked in that same place, and your symptoms seem similar to mine.
Any chance of pics for locating?
bedumon
Wed Oct 20, 2010 11:58 pm
Brianmoooore wrote:If the heater fan is sucking a strong fuel smell into the cabin, then you almost certainly have a leak!
I thought this was the case.......but after filling the tank I put it on the ramp and had a good look around. I couldn't find any leaks whatsoever.
Where are the main points where it can leak?
Thu Oct 21, 2010 9:10 am
bedumon wrote:Where are the main points where it can leak?
If it's a M40 engine, a couple of short bits of hose hidden under the inlet manifold, but it can also be the longer hoses from the back of the engine bay to the engine.
bedumon
Sat Oct 30, 2010 4:25 pm
OK so it's not breaking news but is this the little bugger causing all that smell.......
I can only see one of these? Should there be more?
Sat Oct 30, 2010 5:18 pm
Don't you just love it when you locate the source of a problem and find it will only cost pennies to fix :cool:
