Subframe Mounts....
Hi, not really a diy job without the special puller im afraid ,you can get pattern mounts from ECP people like that but i always find genuine bits last longer and fit better but that could just be me
im sure someone on the zone said they had the puller and was offering to fit them too ,maybe try a search ?
all the best ,paul
all the best ,paul
hope ur binning them shockers glenn
want to do mine all fresh paint and bushes if i ever get to it
www.oldskoolfantasy.co.uk
- Treeman612
Getting them out is hard work, but just about DIY, getting the new ones in needs a press, IMO.
See my previous thread: http://www.e30zone.co.uk/modules.php?na ... highlight=
I DID MINE A FEW MONTHS AGO. I USED A BLOW TORCH TO MELT THE OLD ONES OUT ,AND JUST HEATED THE FRAME ,UP PLENTY OF WASHING UP LIQUID AND USED THE WEIGHT OF THE CAR AN MY TROLLEY JACK TO PRESS THE NEW ONES IN. PERFECT. THE ONLY TROUBLE I HAD WAS THE ALLOY CENTER OF THE OLD BUSH HAD OXIDISED ITSELF TIGHT AND HAD TO SPEND AN HOUR WITH A LONG CHISEL KNOCKING IT FREE THROUGH THE HOLE UNDER THE REAR SEAT. STRESS!!!!!!!!!!!!!!!!!
GOOD LOOK AND MAKE SURE YOU NOTE THE NEW ONE GOES IN IN EXACTLY TH SAME PLACE AS THE OLD ONE, THEY HAVE A CERTAIN SHAPE TO THEM.
same as thatFLO wrote:I DID MINE A FEW MONTHS AGO. I USED A BLOW TORCH TO MELT THE OLD ONES OUT ,AND JUST HEATED THE FRAME ,UP PLENTY OF WASHING UP LIQUID AND USED THE WEIGHT OF THE CAR AN MY TROLLEY JACK TO PRESS THE NEW ONES IN. PERFECT. THE ONLY TROUBLE I HAD WAS THE ALLOY CENTER OF THE OLD BUSH HAD OXIDISED ITSELF TIGHT AND HAD TO SPEND AN HOUR WITH A LONG CHISEL KNOCKING IT FREE THROUGH THE HOLE UNDER THE REAR SEAT. STRESS!!!!!!!!!!!!!!!!!
You could use Powerflex bushes, just burn/hack the old ones out and press (by hand) the Powerflex ones in... job done
Powerflex are in three parts, main bush, stainless tube and top bush and even comes with special lube.
I did this a while back, getting the old ones out is a pain but fitting is easy peasy
BMW E30 344i track car
BMW F31 335d xdrive
BMW F31 335d xdrive
hi all, i have a wobbly rear end(pardon the pun) it is very jerky and i get what feels like sideways wobbling at times. will the rear wish bushes be responsible for this ? it balso steps out quite easily too. cheers.
sounds like the main axle carrier bushes as above mate will cost about 100to fit iirc and you supply bushes or diy as above hth Daz325nut wrote:hi all, i have a wobbly rear end(pardon the pun) it is very jerky and i get what feels like sideways wobbling at times. will the rear wish bushes be responsible for this ? it balso steps out quite easily too. cheers.
THESE BUSHES ARE VERY IMPORTANT AS THEY ARE TWO OF THREE POINTS THAT HOLD YOUR DIFF AN ALL YOUR SUSPENSION TO THE CAR. IF THEY ARE WORN OR LOOSE IT WILL DESTROY THE TRACKING OF YOUR BACK WHEELS AND CAUSE THE BACK END TO WANDER, VIBRATE OR CAUSE UNEVEN TYRE WEAR - ESPECIALLY IF IT IS LOWERED AND YOU RUN ALOT OF NEGATIVE CAMBER.
There was a link to a website showing how to make your own removal tool, but i can't find it anywhere!
Anyone still have the link?
Quaser
Quaser
gareth
my local independand bmw specialists quoted me Ԛ£80ish a while ago to change the bushes on my last E30. they have a tool to allow extraction and refitting without removing the rear subframe. gotta be worth it i reckon!
try here : http://www.jezbraker.com/JJbRacing/Tech/bushes.htmQuaser wrote:There was a link to a website showing how to make your own removal tool, but i can't find it anywhere!
Quaser
there's a piccy of a diy removal tool.
Otherwise you can just drill the rubber out but it is tedious.
Thanks, but thats not the one i was thinking off.
This one involved using iron pipe caps, drilled with a stud to help pull it out!
Q
Q
