Rolling Road result help
afcbob
Wed Jul 14, 2010 10:31 am
Hi in my rolling road why is it only rev to 5000rpm
johnt0709
Wed Jul 14, 2010 4:07 pm
bob think you have a typo in this post - been watching this one in the other thread - should the torque drop off like this?
Phase I - Bodywork Complete
http://www.e30zone.net/modules.php?name ... by+restore
Phase II - 2.8 stroker- Complete
Project II - 325 Motorsport Cabriolet Restoration.
afcbob
Wed Jul 14, 2010 4:26 pm
Thanks mate sorted now. its doing my head in just now not knowing.
johnt0709
Wed Jul 14, 2010 4:34 pm
I would have thought the guys would have been able to pin this down fairly quickly for you - lot of knowledgeable guys on here (myself excluded) - did the guy at the rolling road make any comment?
afcbob
Wed Jul 14, 2010 4:46 pm
The only thing he said was at the very top end it had a small misfire he said try new plugs.
I did asking him about the BHP but he did not know to much about the e30 all he said like everyone here is its not the 320i
Ant
Retired Team Member
Retired Team Member
Wed Jul 14, 2010 8:49 pm
I'm guess 2.5 BHP and TQ waay too high for a B20
If she won't pull past 5K full throttle in any gear then the WOT switch is probably the culprit.
BPR6ES FTW if you get new plugs !!
afcbob
Wed Jul 14, 2010 8:59 pm
no what i mean is when i drive her on the road i can get her to past 5k but what am asking is why on the rolling road does it only go to 5k
Wed Jul 14, 2010 10:29 pm
because the power starts dropping then so its pointless revving it anymore on the RR, prehaps it could be a typo too with the printout
m_jermyn
Wed Jul 14, 2010 11:11 pm
Could it be a Eta motor with a 885 head but eta ecu?
tell us what number ECU it is... Does it have 2 rows of pins or 3 rows?
afcbob
Sat Jul 17, 2010 4:58 pm
ECU code Bosch 0 265 103 041
As far as i know thats 2.5 ecu
m_jermyn
Sun Jul 18, 2010 1:34 am
Where did you get this ECU number from? Glove box or under the steering wheel?
afcbob
Sun Jul 18, 2010 12:08 pm
Glove box
m_jermyn
Sun Jul 18, 2010 12:14 pm
OK that is the wrong ECU, the glove box ECU is for your ABS.... Look underneath the steering column above the pedals... What have you got?
afcbob
Sun Jul 18, 2010 12:42 pm
325i/is/iX
E30
M20/B25 (170hp)
87-91
0 261 200 173
Bosch Motronic M1.3
m_jermyn
Sun Jul 18, 2010 12:56 pm
Well it is indeed a 325i ECU the thing is a 325i should rev to 7000 although they wont make power all the way up there they will rev that high..
Something is not right.... Wonder what would happen if you plugged in another 325i ECU?
I wonder if the throttle position switch is working properly? Could also be a fueling issue maybe your fuel pressure regulator cant keep up..
afcbob
Sun Jul 18, 2010 1:15 pm
This may help with you say the fuel
afcbob
Sun Jul 18, 2010 1:17 pm
It does rev to 7000 when am driving it
BadDave
Sun Jul 18, 2010 2:08 pm
Just a wild guess here.
Could it just be a stock 2.5 lump in need of a good service
afcbob
Sun Jul 18, 2010 3:49 pm
I was told the torque is to high to be just a 2.5
SGP
Mon Jul 19, 2010 12:05 am
Very mysterious... lots of unanswered questions. What's the other thread?
If it ain't broke..
Fix it till it is :)
afcbob
Mon Jul 19, 2010 12:09 am
Tell me about it its doing my head in now.
The other thread is http://www.e30zone.net/modules.php?name ... c&t=172423
GeoffBob
Forced Induction Specialist
Mon Jul 19, 2010 9:15 am
afcbob wrote:Tell me about it its doing my head in now.
afcbob, I have posted an answer for you here at your original thread.
You need to tell me how the rolling road operator measured your engines RPM. Did he put a clamp on one of the plug leads, or did he calculate your engine speed based upon the speed of the rollers? The reason I ask is because I think the x-axis (RPM) of your graph may be in error.
