what hassle will i have lowering my 316 with a m20 2litre
irish320i
Post Thu Sep 15, 2005 1:45 pm
will there be a problem with spring rates
Gwynleym10
Post Thu Sep 15, 2005 2:14 pm
Do you still have 316 suspension?
Dual wheel carriers -------195litre Fuel Tank
London 2 Cape Town
www.Overlandinthesun.com
irish320i
Post Fri Sep 16, 2005 9:25 am
yea still running the 316 setup with 320 front brakes
irish320i
Post Fri Sep 16, 2005 9:29 am
how much is needed to change it across to 320 setup
dazleeds
old skool raver
old skool raver
Post Fri Sep 16, 2005 9:30 am
front and rear shocks and front and rear brakes
including front legs
www.oldskoolfantasy.co.uk
irish320i
Post Fri Sep 16, 2005 9:55 am
so i need the full hub s of a 320 for the front do i need to change the complete trailing arms at the back
dazleeds
old skool raver
old skool raver
Post Fri Sep 16, 2005 9:57 am
if you currently have drums at rear and want discs etc then youll also need the correct trailing arms
idealy you just want all the running gear from a 325/320i that has discs all round
irish320i
Post Fri Sep 16, 2005 10:43 am
i have drums at the back will it be a problem, to lower it with the right springs without changing the arms there not easy to get over here without paying a fourtune
dazleeds
old skool raver
old skool raver
Post Fri Sep 16, 2005 10:45 am
no mate pretty strate forward undo rear shocks jack up as high as u can and rear springs shoult come out fronts clamp em up and swap em
irish320i
Post Fri Sep 16, 2005 10:58 am
i can do the work no problem its just id like to use the 320 lowering springs cause they ve probaly a different spring rate but are you saying i cant do that without changing the struts and the trailing arms sorry for saeeming thick
Gwynleym10
Post Fri Sep 16, 2005 11:03 am
Actually you probably can fit 320 lower springs to normal struts and you def can fit them to normal rear suspension.
Are the brakes vented?
London 2 Cape Town
dazleeds
old skool raver
old skool raver
Post Fri Sep 16, 2005 11:14 am
im pretty sure you could just fit em anyway mate
i know people fit the mtec springs on 316s etc
rear is a def strate fit
irish320i
Post Fri Sep 16, 2005 1:03 pm
thanx a million lads thats what i was looking for . i changed my disks and calipers when i changed the engine there vented now
