Hey fellow zoners , my e30 318i m40 was leaking engine oil in between where the engine block bolts onto the gearbox bellhousing and i decided to investigate this today and found that the oil leak was because the gasket between the bottom part of the rear crankshaft oil seal housing where the housing bolts to the block with 2 bolts from undernath has persihed and this is what is causing the oil to leak through, does anybody know the part number of this gasket ?
thanks in advance
rear crankshaft oil seal housing gasket m40
- Brianmoooore
