has my heater broke or is it worse??
I fired up my 318i tourer the other day...its been sat for a while but will be taxing it shortly, it started fine and had plenty of fuel in so i thought i'd live it runnin for a bit as i had a tidy round the drive. i walked pass to see the windows all steamed up so quickly turned the engine off. there way loads of water in the passeger footwell!! and the temp gauge was will up, my neighboor sugested it was the heater box and that disconectin the two pipes in to it and looping the together as the removing the heater for the system may sort it, i did this with some copper pipe but it still over heats...any clues or has the head gone? many thanks Matt
IF YOU CAN'T FIND A GOOD SPORT,BUILD YOUR OWN! "IF YOU BUILD IT, SHE WILL CUM"
Banjo1981
Sound's like what I had not long ago.
You need to replace the heater valve on the heater matrix.
Have a look here:
http://www.e30zone.net/modules.php?name ... c&start=25
It's a fairly straight forward fix tbf, just a bit fiddley in parts.
Good luck!
Have a look here:
Good luck!
- Brianmoooore
Another case of someone ignoring the coolant cap recall?
- Brianmoooore
It was very widely publicised at the time.Alex wrote:Or a case where one doesnt know about the coolant cap being a recallBrianmoooore wrote:Another case of someone ignoring the coolant cap recall?
the coolant cap recall was over 10 years ago IIRC, I doubt it has made it this far without a replacement !
- Brianmoooore
About half I see still have the old cap!e30topless wrote:the coolant cap recall was over 10 years ago IIRC, I doubt it has made it this far without a replacement !
