I was sort of thinking an E30 switch to fill a blank above the headunit?
TIA.
That is NOT a switch! The rear window isolator switch is square, and doesn't have a red band.jonny323i wrote:found it looks like a cut off switch to stop the back windows working on a 4 door so dead simple wiring as its just 2 pins
I agree, if you want it to stay up all of the time then this is the best option. If you want a bit more control you can always put a rear fog switch in line with this so you can listen to the radio in the car wash or summat. The switch is dead easy as it's only 2 spade terminals on the back so it doesn't actually matter which way you wire it.Alex wrote:the easiest thing would be to wire the remote switch to the ignition live?
