no spark at plugs please help
timbo2
hi just finished a engine swop on my g reg e30 from a 318 to 325, having a problem getting spark to the plugs, tested ECU, coil and had new battery, rotor arm, dizzy cap, checked all conections including round screw in ones, fuses and relays still no luck, any help would be great,
mrLEE30
check crank position sensor and wiring
then check power to ECU from the DME relay
