E36 subframe
stup86
Sun Jun 13, 2010 9:31 am
Can it be swapped for an E30 one?
Stu
Parts needed:
M40/M20 ignition coil with high voltage lead
Bulletje
Sun Jun 13, 2010 9:39 am
Nope, that wont fit.
Sun Jun 13, 2010 7:52 pm
Yes, it will bolt up to the E30, getting the engine and ARB on is another matter
Chris
Sun Jun 13, 2010 11:32 pm
Front or back :?
steviec_lj
Mon Jun 14, 2010 1:05 am
Asked this the other day in another thread with a few other bits about Retro-fitting some bits from other E30's and had no reply. So I went outside and tried it.
The E36 engine mounts bolt further back than the E30 one, the wishbones would fit, if they were 3inches longer and further forwards.
Its not worth the hassle. BMW changed the design for the M50.
stup86
Mon Jun 14, 2010 7:15 am
Cheers guys.
I asked for 2 reasons:
I'll be putting an E36 P/S rack on soon and thought I may as well change the front subframe whilst I'm at it.
also, my subframe is looking a little tatty, and was thinking I could save cleaning it up.
Oh well.
Stu
Parts needed:
Mon Jun 14, 2010 9:40 am
The engine sits about 100mm further back on the E36 subframe, you would need to give the bulkhead some angle grinder action
stup86
Mon Jun 14, 2010 3:55 pm
DanThe wrote:you would need to give the bulkhead some angle grinder action
Hmmm, not really feeling that if I'm honest Dan!
Parts needed:
