i know where it is but whats its purpose?
what the difference between them all?
im guessing from what i have read that the 3:91 is the better one ?
which car are they one?
lsd i need educating
Chaos
none of them are "better" than any other.
basically the higher the number the lower the gearing.
so a 3.91 will give better acceleration than a 3.64
but at the expense of mpg and refinement (more revs at high speeds)
its purpose is to allow both wheels to get traction, instead of the wheel with least resistance spinning it all away.
it also has the "benefit" of making a car more lively at the rear under power, cos as both wheels can spin u can then "push" the car wide, or even spin it on the spot - eg a donut.
Chaos
causing havoc and mayhem wherever i go
there are 4000 topics and posts on LSD's there ratios and how they work, how u test for one, just LOOK in the tech section
Chaos
and for the effort in typing that whingeing drivel u cud instead have helped the guy out.Simon13 wrote:there are 4000 topics and posts on LSD's there ratios and how they work, how u test for one, just LOOK in the tech section
Chaos
Dan318-is
dont wona stick my nose in but :yeahthat:
wayne long time no c mate how r u
Richy325iTouring
he was only asking for helpSimon13 wrote:there are 4000 topics and posts on LSD's there ratios and how they work, how u test for one, just LOOK in the tech section
calm the fcuk down
