The biggest contrast by far from my other cars is the electrical system, and to make matters worse I've been removing an old alarm setup from the Tourer. I've now got it all out, but there are a few loose connections that I need to identify and tidy up all the loom. Here's the ones that are really bugging me:
The one in the red circle (thick yellow/red wire) is always live independent of key position, should it be plugged into something?
The one in the green circle (one green, one green/blue iirc) has one terminal that's live when the key is switched on, and the one in the blue circle (thin brown and violet/red) has no live leads, but I've traced this one (by accident) to fuse #28... so maybe it's an accessories plug?
By the way, what are those massive connector blocks in white? I'm not used to having a car whose wiring diagrams span a whole chapter... my classic Fiats have it all in one A4 page...
Thanks for your input on this!
Cheers, Eddie
