320i to 325i?
fozzy325is
Post Sun Sep 11, 2005 6:26 pm
whats involved in swaping a 2.0 to a 2.5 what would i have to change other than the engine.
Hyperion
Post Sun Sep 11, 2005 8:25 pm
If you want 325 performance, you can install a 325 trottle body and a chip, But if you already bought the 325 engine, skip my idea......
Chaos
Post Sun Sep 11, 2005 8:28 pm
Hyperion wrote:If you want 325 performance, you can install a 325 trottle body and a chip,
that will NOT give u 2,5 performance.
Chaos
causing havoc and mayhem wherever i go
Chaos
Post Sun Sep 11, 2005 8:30 pm
the acutal swap i beleive is pretty simple.
the engines use same mounts, same connector plug to the loom etc.
ud need to change the ecu
add the oil cooler
oh and change the diff too.
tbh unless the car is well modded or specced REALLY high it is imo easier to sell it and buy a real 325i
Chaos
Hyperion
Post Sun Sep 11, 2005 9:07 pm
oops i stand corrected.
SO i say a 325 trottle body, chip and a turbo, will give you more than enough power....
Ziggy
Post Sun Sep 11, 2005 10:53 pm
& cost a helluva lot more & be a helluva lot more bother than fitting a 2.5... :roll:
Chaos
Post Sun Sep 11, 2005 11:05 pm
aint that the truth.
Chaos
