Hhhhmmmm
BenE30
Post Sun Sep 11, 2005 2:02 pm
Right,
i have been told by my dads mate (mechanic) that my fuel pump is on the way out! my car is a 318 iS and i was wandering if i could get one from the scrap yard say of a 320i, in other words does it have to be off a 318 iS?
jonb
Post Sun Sep 11, 2005 2:20 pm
all pumps are universal. but the carryers arnt.
the i.s has a twin pipe carryer. the 6 pots have the single pipe carryer. if your good at sodering then just swap the pump onto your carryer.
smithy318i
Post Sun Sep 11, 2005 2:23 pm
test the scrappy pump with 12 volts before buying it. After sitting around for a while they sieze up and are absloutly useless.
BenE30
Post Sun Sep 11, 2005 2:24 pm
ok but would one off a 318i work?
*looks for soldering iron*
smithy318i
Post Sun Sep 11, 2005 2:29 pm
the 318i has 2 pipes.
smithy318i
Post Sun Sep 11, 2005 2:31 pm
how did the mechanic come to the conclusion that the pump was on it's way out?
BenE30
Post Sun Sep 11, 2005 2:40 pm
Its weining!! i noticed it the other day!!
Post Sun Sep 11, 2005 2:47 pm
smithy318i wrote:the 318i has 2 pipes.
You can use a two pipe pump in place of a single pipe if you can think of a way to blank off the second pipe. e.g. a short piece of fuel hose and a short piece of 8mm(?) solid bar.
320Touring
Post Sun Sep 11, 2005 3:09 pm
could you not make a 2 into 1 pipe?
cos if the pumps are the same then the flowrate must be similar?
ergo-regardless of 1 or 2 pipes, the total voulme of fuel is the same?
Post Sun Sep 11, 2005 3:17 pm
nothing to do with flow rates. The second pipe is the return pipe to the tank. Some models have the return pipe going into a stub pipe on the tank, so don't need the return on the pump.
320Touring
Post Sun Sep 11, 2005 3:19 pm
Brianmoooore wrote:
320Touring wrote:
Brianmoooore wrote: You can use a two pipe pump in place of a single pipe if you can think of a way to blank off the second pipe. e.g. a short piece of fuel hose and a short piece of 8mm(?) solid bar.
gotcha :cool: :D
