bleeding cooling system
Fraz06
Fri May 28, 2010 9:18 pm
Hey all, Can you bleed the cooling system without bleeding the system at the bleed nipple on the thermostat housing ? as the bleed nipple on the housing has snapped off :-( as i have replaced the coolant but can't bleed the system from the bleed nipple. any suggestions how else i could bleed the system ?
cheers guys
