I was driving to work this morning in drive when i came to a bend so i let off the pedal and cruised round.. As i put my foot back down the car just reved with like it was in nuetral.. so i pooped it into nuetral then back into drive and it worked fine again.. this is the first time i have experienced this.. whats wrong?...
Edit* sorry its a sports autobox
Thanks, Andy
Autobox gear slip
Driving my digger!!!!
Could be many reasons.
Can you test the car a little more? Does it brake on low gear? Does it slip in reverse? Can you hear a weird noise when you get this problem? When you have the problem does it affect reverse?
If reverse works when forward doesn't problem would be A clutch pack, if not it's simple you need to change filter and oil.
Also when warm put it in all gears then park again then check oil. Could also be low on oil.
as i say its only happened once since i have owned it for just over a year.. i have checked the oil at the weekend and its between the marks
Andy
Andy
Ok the oil is low when its hot... how do i go about topping it up?
Yeh figured it out in the end... but now i have a problem
I took the car for a drive and when i sit on idle its fine but when i put the car into drive or reverse the revs climb to about 2k so the car bangs into gear and sends me flying... also the "i" light is on
