88 M3 ABS Light
kieran325
Post Sun May 23, 2010 8:23 pm
I had to jump start the M3 this morning, had a barbecue over the weekend and some dozy sod had left the door open for 48hrs :-x
It fired up no problem and went for a quick spin and noticed the ABS light won't go out :?
Is the ABS relay knackered ??
I've searched the zone wiki and this is what it's telling me.
Has anyone got one that will work for an1988 m3 ???
Cheers.
Francisco
Post Sun May 23, 2010 9:30 pm
Worth cleaning the sensors first. It's the most common fault.
mrLEE30
Post Mon May 24, 2010 7:20 am
what does the ABS light do:
1. come on with ignition and stay on? - ABS relay/fuses to be checked
2. go off after starting then come on once moving - sesnor or sensor wiring
the relay has a diode that protects the circuit from over voltages, jump starting can cause this to fail.
kieran325
Post Mon May 24, 2010 8:46 am
mrLEE30 wrote:what does the ABS light do:
I think it's the ABS relay too, fuses checked - I'm going to swap the relay over from my touring and try it.
Anyone got a ABS relay :wink:
Post Mon May 24, 2010 8:47 am
kieran325
Post Mon May 24, 2010 9:02 am
Anymore info Brian.
Post Mon May 24, 2010 9:04 am
Need the answer to the questions!
kieran325
Post Mon May 24, 2010 9:07 am
It stays on all the time.
Post Mon May 24, 2010 9:17 am
In that case you have almost certainly blown the ABS over voltage protection relay.
On a RH drive E30 it's silver in colour, and clipped to some metalwork just above and to the right of the ABS ECU.
kieran325
Post Mon May 24, 2010 9:21 am
Any idea's on the location on the M3 ??
I've had a look under the scuttle on the pass side and found 3 relays - black,silver and yellow.
gazm3
Post Mon May 24, 2010 1:58 pm
kieran325 wrote:I had to jump start the M3 this morning, had a barbecue over the weekend and some dozy sod had left the door open for 48hrs
just wrong, You dissapoint 8O
kieran325
Post Tue May 25, 2010 2:45 pm
^^^ Sorry :o:
Anyone know the excact location of the ABS relay :?
