Old/ Stale fuel
Fri May 21, 2010 11:02 pm
With my collection of scrap on the drive, I now have 2 E30 fuel tanks removed from cars.
The tank from the touring, which had about 1/4 tank of juice in it when I binned it in October. Then the tank taken from the chromie which probably has about £10 worth of fuel in it from November time.
Obviously I can't just tip it down the drain.
Do you reckon a car would run like a dog on it? The soarer has knock sensors :)
sihooker
Fri May 21, 2010 11:11 pm
I'd add it a bit at a time to a tank that was at least half full. I certainly wouldn't waste it!
BadDave
Fri May 21, 2010 11:13 pm
IIRC it usually goes "off" in about 6 months or so(that's why bikers drain the tanks or add fuel conditioner over the winter months)
I'm guessing here Lee, but if you were to mix a little of the old stuff occasionally with a 1/2 tank(or more) of fresh fuel, you may get off with it.
e30daniel
Sat May 22, 2010 12:06 am
i usually just use old stuff in a wee runaround. you got any extremely non performance oriented cars. atleast then you dont need to worry about pre ignition or knocking on a runaround.
psychochild187
Sat May 22, 2010 10:20 pm
any car that eats fuel in a none meausred way like a e30 or old range rover or ford. would be fine on it .
i would tip it in, see how it runs and top up if its not great.
or tip it in the garden mower or lite fires with it if its that yellow and old.
Sat May 22, 2010 10:48 pm
Chuck it in the golf
beardymat
Sat May 22, 2010 10:52 pm
just chuck it in something and top up with fresh, it will all be good.
grantfk10
Sat May 22, 2010 11:23 pm
I put the cabby off the road for 6 months every year, and leave it sitting with a ful tank 8O Seems ok when she goes back on the road in the spring :?
jbh
Hartge Crew
Sat May 22, 2010 11:33 pm
I bought a 325i a few years back that had lay for around 2 years and it had around half a tank. it fired up and drove onto the trailer with no issues.. it got fixed and went through its test with the same fuel in it.. all i did was stuck some redex fuel treatment in and gave it a bit of a clean out on its way to the test...
grantfk10
Sat May 22, 2010 11:40 pm
jbh wrote:I bought a 325i all i did was gave it a bit of a clean out on its way to the test...
I bet you did! winkeye
jbh
Hartge Crew
Sat May 22, 2010 11:42 pm
you know me to well Grant.. :wink:
my sis ran it for a while after it was through its test and never had any problems concerning running issues.. the only problem was the driver :mad:
Sun May 23, 2010 12:28 am
My 84 318i started with 18 month old fuel
my cabby had been sat for around at least 6 month + that i know of with old fuel in (not much like) but still started fine on it and ran fine, untill it ran out :roll: the dvla says it hasnt been on the road since october 2007 so could of been older
