Anyone know what these oil seals do and where i can get one?
Stifla
Wed May 19, 2010 7:54 am
Ive got a slight leak on the top half of my m20, straightaway i replaced the rocker cover gasket thinking it was that but there its still losing oil.
I thought then that the only other obvious place would be the camshaft seal but then i saw these little buggers.
Anyonw know what they are, what they do and where i can get them?
[img][img]http://img59.imageshack.us/img59/3104/cadshot.jpg[/img]
Uploaded with ImageShack.us[/img]
Wed May 19, 2010 9:30 am
BMW have plenty. Very common source of oil leaks, and there's two more at the back.
Stifla
Wed May 19, 2010 10:00 am
Brilliant, thanks guys!
P.S. i cant seem to find them or the part numbers on realoem, do you have any ideas?
nickfromgills
Thu Aug 12, 2010 1:39 pm
They're under the "Valve Timing Gear - Cam Shaft" section on the RealOEM site. Component is known as a 'blind plug'. You've probably sorted this by now but hope this helps others searching.. :)
