320i info any one in the know?
fozzy325is
whats is motronic? and whats the other one called, and what were the change over periods?
dazleeds
- old skool raver
old system was jtronic believe change over was 1987
www.oldskoolfantasy.co.uk
fozzy325is
whats the difference?
Richy325iTouring
i prefere the later system and i think they slightly up on power by a brake lol
later system montronic has the distributer cap on the cam jetronic early syetem has it on the side of the block
Hyperion
one starts with J and the other starts with M
Hyperion
but seriously, check out this link i found. it might help.
http://www.auto-solve.com/mech_inj.htm
koos
dis sommer rerig a suid afrikaanse ding te se!!!!!!
Hows things on that side of the planet?
A1BMW325iSport
K Jetronic was used on early E28 m20`s,
early e30`s used L Jetronic except 325i from launch in 85 had motronic
fozzy325is
so providing my 320i is motronic wich i now belive it is if i get an ecu off a 2.5
and afm will a 2.5 drop strait in bar changing the diff ratio?
Ziggy
I might be wrong, but I think you can get a zone chip off ant, & just plug it into the 320 ecu & it'll all work fine...
fozzy325is
that would b nice!!!
Hyperion
howzit, Koos. Things are cool here, spring is starting, so its gonna start raining, but the suns out, times for Braais, Beer, and bikini's.koos wrote:dis sommer rerig a suid afrikaanse ding te se!!!!!!
How is it up there?
koos
Pretty good, but on the flip side it's starting to get cold here, had a sh*t load of braai's, every oppertunity we got. Enjoying the sunshine while it's still hanging around, see you around.
Totsiens
Mitch
Totsiens
Mitch
