Wheel and Tyre help
CpnSpankyPantz
Thu May 06, 2010 3:29 pm
Hello,
I've found the wheels I've want in 16x8 with an et10. Does anyone have any info/suggestions on what size tyres to use? Ideally I'd like it to be similar (no bigger for sure!) than what I'm using at the moment - 205/55/R15's on the standard 15x7 bbs.
Or will the wheels fit?! Haha! They are 4x100 :D
Am I right in thinking a lower profile will lower the car a touch, but also provide a touch more arch clearance? My car is lowered 60mm...
bimanut
Thu May 06, 2010 3:34 pm
The wheels will fit being 4x100.Dont know about the et bisuiness i dont understand it.
Having low profile tyrres on your car with a 60mm drop will be sound (stop any rubbing issues.)
As for the tyres i`d hardly call a 55 a low profile more like 35`s & 40`s.I would have thought that 205`s would be enough possibly squeze a 215 in there.(not sure.)
CpnSpankyPantz
Thu May 06, 2010 4:05 pm
Thanks!
I think I'll run some 195s or 205's at the most up front, as I have "issues" with my wheel arches currently, and a bit more clearance would be nice...!
I was thinking 195/45s or 205/45s up front and 215/45 on the rear but not sure if they will catch?
Thanks in advance...
koh
Thu May 06, 2010 4:22 pm
dont know what the standard e30 offest is but et10 is going to sit out further,i would put a wheel on and see how close to the arch lip it is,then choose a tyre with enough stretch to not rub
CpnSpankyPantz
Thu May 06, 2010 4:25 pm
The standard offset is 25 on a 15x7 I believe!
I'd order the rims off t'interweb, so can't offer them up...
CpnSpankyPantz
Fri May 07, 2010 11:37 am
Anyone else?
orangecurry
Fri May 07, 2010 11:43 pm
Centre bore should be 57.1 from memory.
205/55/15 is the same rolling diameter as 205/50/16, or 225/45/16.
You may struggle with an offset of 10.
charlE30
Sat May 08, 2010 10:54 am
Have a play around with the tyre size/offest calculator on this link http://www.e30zone.net/e30zonewiki/inde ... calculator
BMW F31 335d xdrive
CpnSpankyPantz
Mon May 10, 2010 10:38 am
Awesome, thank you!
I've also spied 16x8s with an et of 20 and 25... Would these work?
