320i coupe cold start problem
Ajsingh
Hi, i have a delphin grey 320i coupe & its a dream to drive but not when it doesnt want to start in the mornings. Iv changed all 6 plugs, the dissy cap, new ignition leads, new ignition coil, 2nd hand idle control valve and even tuned the CO. This made all the differance and the car was okay for a while, but now the problems back. The engine turns over and nothing happens, slightly open the throttle and it sounds as if its firing on one or maybe two cylinders. Open the throttle full at this point and the all 6 fire up, but sometimes it can also take abit of fiddling with the throttle (closing n slightly opening) to fire it up. Please could you help me as this is very frustrating. Many thanks...... Aj
H35-24
Had the same problem with my 1988 320i.
I swapped the complete fuel rail with injectors pressure regulator and wiring harness for a used one of a 320i with only 50.000 miles on the clock. Now it starts without any hassle, I only have to "catch it"with the throttle when it fires from cold (starts in uder 2 seconds, but dies if I don't hold the revs on the throttle for a second or so). When hot it fires after 3-4 seconds, no throttle needed. Not perfect but it works fine.
I'm going to see if a new Idle control valve can't fix it so I don't have to catch it.
Remember to clean the harness connector with some contact spray before fitting new part.
Why is there not enough time to do it right, but allways enough time to fix the errors - I borrowed that, just so reallistic in my line of work.
surj
have you changed the blue temp sensor as this was the same on mine
Ajsingh
Surj, did ur car only do it sometimes? Like would start okay sometimes & then sometimes have the problem?.. By the way, where can i find the blue temp sensor n what does it do? I really appreciate the help guys, thank you
H35-24
Id did and nothing changed. Then found the fuel rail.surj wrote:have you changed the blue temp sensor as this was the same on mine
Ajsingh
To replace the fuel rail, does the inlet manifold need to moved or taken off as its kinda tight???
Ajsingh
Any other ideas anyone???
