Hi,
Im looking at a 320 convertible auto. Theres a dial near to the handbrake that can be turned to E, S, and 3:2:1 irrc.
Just wondering what this is, im thinking it must have something to do with the diff, ive tried searching but searching but cant find anything?
Cheers!
Dial next to handbrake
switchable auto box ,
so you can 'switch' the switchable gearbox from either normal 1.2.3 driving to e=economy or s= sport,
these gearboxes are troublesome unfortunately, and when they fail are a pain in the arse
just drive it,
have you driven auto before ? if so then it's very much the same .. in sport mode it will 'hold out' in gear a little longer,
if the engine seems to rev higher without the car picking up speed it's slipping, that's not good
also check the car selects gears properly when cold,
