Difference between 325 and 320
spence_star
Fri Apr 23, 2010 12:43 pm
Guys,
I dunno if this has been asked before, im not that clued up with engines all i know is that 320's and above are 6 cylinders compared to the 316's and above.
I want to know is the following;
What makes a 325 engine different to a 320 if they are both straight 6's?
What components need to be changed on a 320 to perform like a 325?
Do you have to do big engine rebuilds like top and/or bottom ends?
Is it a case of a different ECU?
The reason why im asking is because how do i know im buying a genuine from factory a 325i and its not a 320 with modifications?
Returned after many years out.
phil540uk
Fri Apr 23, 2010 12:58 pm
The 325 is a totally different engine to the 320. the 320 is 2 litre, the 325 is 2.5. The 325 has a different head - it will have 885 instead of 731 written on the side of it that's probably the easiest way to tell other than looking at the engine number.
There's also differences in the sizes of the front struts, and the 325's have disc brakes on the back instead of drums.
Phil
lowey
Fri Apr 23, 2010 1:14 pm
About 50 of these.............. :D
1989 325i SPORT Brilliantrot
spence_star
Fri Apr 23, 2010 2:09 pm
Im so dumb how did i miss the biggest obvious clue. 2.0 and 2.5
How about with the 323 did they make a 323 in these engines?
beep
Fri Apr 23, 2010 2:12 pm
yeah, but only in pre-facelift from 1983-85ish...
Grrrmachine
E30 Zone Wiki / Team Member
Fri Apr 23, 2010 4:02 pm
Only way to convert a 320 to 325 is to rip the motor out; very little is interchangeable on the actual engine, and because of the power outputs they had different gearboxes and differentials which meant a different propshaft too. You can mate a 325 engine to a 320 transmission but the gearing will be very sporty :)
Also, BMW engines don't take well to "tuning", so bolting on induction kits and fat exhausts will make f-all difference to a 320. So if you want power, don't think about modding a 320; just buy a 325 to start with.
spence_star
Fri Apr 23, 2010 4:47 pm
I would go for either a 318is or a 325 which ever mint one i come across first
Martinaston
Fri Apr 23, 2010 5:19 pm
If its a 320 with a 2.5 lump in it, it will still say 320 on the log book under model name.
There is NO nucleus.
nickso
Fri Apr 23, 2010 6:01 pm
also check the vin plate above the headlight (i forget which side it is)
the VIN plate will tell you what car it was from the factory. check the chassis number on the plate and below the windscreen against the V5 to confirm its the correct VIN plate/car. then all you have to do is check if its a 2.0 or 2.5 engine using the methods suggested above.
confused yet :mad:
'88 e30 328i M52 track bint.
