Wheel offset.
Can i fit a 7.5j wide wheel with the offset of 35 to the front of my e30?
Will it stick out loads or will it be sat further in the arch?
Parts Wanted:-
Tech 1 Side Skirts,
Borbet B Alloys or Borbet A Alloys, Electric Sunroof Motor Cover,
Opening Rear Quarters
Tech 1 Side Skirts,
Ziggy
The outer edge will sit ~5mm further into the arch than a 7J ET24 BBS, & the inner edge will be ~17mm closer to the strut.mykez69 wrote:Can i fit a 7.5j wide wheel with the offset of 35 to the front of my e30?
if the offset is 35, i could fit 10mm spacer then i would have 25 which is the correct offset for the front?
This is so stressfull i just want a set of wheels lol
i found a nice set of borbet a's in 15 inch, which would look pretty good, stagered fitment.
Parts Wanted:-
Tech 1 Side Skirts,
Tech 1 Side Skirts,
It would bring the wheel out more so got to be careful with which size spacer you use. I had 17" ET35 alloys on mine and just needed a 3mm spacer to clear the front struts.
Just be patient, the right set will come along, shame i've sold all my wheels
15" will need a serious drop, 16" look better
Thanks for the help guys, I think my car is lwoered about 80mm.
All in all 15 or 16 inch wheels not much differnt by the time got lower profile tyres on the 16 look about same aize as 15 with bigger tyres.
Decisions
Decisions
Parts Wanted:-
Tech 1 Side Skirts,
Tech 1 Side Skirts,
well, i not sure if arches are rolled or not.
i have my eye on some borbet a's and the offset is 15. all 4 are 9'' inch wide.
i think i will need to roll arch on the back
Parts Wanted:-
Tech 1 Side Skirts,
Tech 1 Side Skirts,
but when i put the drift wheels on it might look daft with arches rolled and no huge wheel lol hmmmm
hate cars lol
hate cars lol
Parts Wanted:-
Tech 1 Side Skirts,
Tech 1 Side Skirts,
You won't notice it the rolled arch. Think you getting confused with flaring the arch.
Look inside the arch and you will see the lip that will get rolled and give you a couple of more mm space
ohhh yeah, sorry,
mine has been rolled then
thanks for your help matey, really appreciate it
Parts Wanted:-
Tech 1 Side Skirts,
Tech 1 Side Skirts,
