318is LSD
Daz318is
Mon Apr 19, 2010 8:57 am
Hi
Could some one tell me how i can tell if my G reg 318is has an LSD? its off road at the moment so cant drive it to check, are there some numbers or something i could look for ??
Darren
fowler
Boost Junkie
Mon Apr 19, 2010 9:28 am
there should be a tag on the diff it should begin with S then the ratio. Off the top of my head if its got a LSD the ratio should be 4.10 so the tag on the back plate should
read S4.10
if not the only way is counting the turn ratio and if both wheel turn in same direction once the car is jacked up
and go and get spec from local BMW dealer
EX A-Tech Workshop bitch !!!
gone but not forgotten
e30_sam
Mon Apr 19, 2010 12:32 pm
i was having trouble finding out if my is had a lsd found out it did and it was a 4.10 mine is on a h plate yours should be the same
Judasgoat
Tue May 18, 2010 1:47 pm
Hi,
Just checked mine on my 1990 318is and it just reads 4.10 without the 'S' prefix. Would I be right in assuming then that this is a non-lsd model?
jbh
Hartge Crew
Tue May 18, 2010 1:49 pm
yip just an open diff im afraid.
