washer jets not working?
k17byo
Fri Apr 16, 2010 9:25 pm
washer jets not working? the wipers still work!
any ideas?
its the one with the 3 pumps if that helps?!?
any help much appreciated! :D
Paul325ITouring
Fri Apr 16, 2010 10:33 pm
Do you know if the pump is pumping could just be a failed or cloked pump
Paul325ITouring
danbear
Sat Apr 17, 2010 12:26 am
if the pump is working, the only other thing it can really be is blocked jets.
k17byo
Sat Apr 17, 2010 3:11 pm
they dont even make a noise! so im guessing their not getting power?
Paul325ITouring
Sat Apr 17, 2010 5:51 pm
Check for power at the pump . If you have power there I would say pump has gone
Sat Apr 17, 2010 7:00 pm
Which washer jets aren't working? Headlamp or screen?
If it's the screen washers, is it the normal wash or intensive wash that's not working?
k17byo
Sat Apr 17, 2010 9:16 pm
its the intensive and all 3 arent workin!?! :?
bobbin1982
Sat Apr 17, 2010 11:01 pm
I had this problem... it just turned out to the pipe had fallen off in the bonnet...(assuming we are talking about windscreen)
Driving my digger!!!!
Sun Apr 18, 2010 10:00 am
bobbin1982 wrote:I had this problem... it just turned out to the pipe had fallen off in the bonnet...(assuming we are talking about windscreen)
Pipe falling off won't stop the motors working.
bobbin1982
Sun Apr 18, 2010 11:28 am
ah my mistake didnt read hard enough sorry..
jake777
Mon Apr 19, 2010 6:09 pm
one of my washer jets is blocked too aswell as the headlamp ones not working does anyone know how to unblock the washer jets?
jaxon
Tue Apr 20, 2010 8:56 am
My washer jets have been blocked on all the E30s I've owned, it seems to be a common problem and it can be a bastard to get all the crap out of them.
I got good results on my new E30 by taking them out and soaking them in very hot water, then using the G string from a steel strung acoustic guitar to have a good poke around in both the jet holes and the hole the pipe connects to. Using a pin to move the jets around in their housing a bit is also a good idea.
