swap motronic ecu no. o261 200 073 35 pin for compatible
TOMMYSPANNER
Fri Apr 16, 2010 2:48 pm
motronic ,any ecu that i can swap in as plug n play in place of 0261 200 073,it has to be a 35 pin connector so 173 is not a straight swap as it has 55 pin plug any advice greatly appreciated, would an adapter be an option to fit 0261 200 073? also what parts needed to change radiator from both outlets on the left, to later model,with outlets diagonally opposite best regards.
Ant
Retired Team Member
Retired Team Member
Fri Apr 16, 2010 3:26 pm
why ???????????????????
073 a but thin on the ground but I have a few.
needs a like for like swap dude.
TOMMYSPANNER
Sat Apr 17, 2010 1:45 am
surely dme 081 would fit, i think it was a 35 pin ecu ------ plug. with a 24 pin chip?
