Please Help! No spark...
Nay
Channel Island Crew
Channel Island Crew
Wed Apr 07, 2010 4:29 pm
We had the car starting earlier, and when i dropped the throttle back to idle the engine just cut. Since then it hasn't been sparking... we think!
New spark plugs, Ht leads just stopped sparking we think and are now rather confused.
Any ideas?
Uni is killing the project.
ross_jsy
Wed Apr 07, 2010 4:30 pm
How you testing it Nathan?
Nay
Channel Island Crew
Channel Island Crew
Wed Apr 07, 2010 4:39 pm
taking out the spark plugs and keep them connecred, turning the engine to see if they spark.
What do u recommend doing? and shouldn't u be working!
ross_jsy
Wed Apr 07, 2010 4:41 pm
You have to ground them out for them to spark.
I am working...... :teehee:
Nay
Channel Island Crew
Channel Island Crew
Wed Apr 07, 2010 4:45 pm
meaning placing them onto metal whilst turning the engine? well, thats what we were doing....
SteSE
Heading for the Naughty Room
Wed Apr 07, 2010 4:53 pm
If your not getting a spark at the actual plugs take the lead from the coil to the dizzy of at the dizzy end and see if your getting a spark there.
Coil, ECU and i think crank sensor can cause loss of spark.
Very unlikely that all plugs and leads would fail at same time tbh mate. Must be something else, maybe you've knocked something?
87.5 Impact FM
PS3: gary_bunter
1986 325i resto - M52'd
C plates are fastest
Nay
Channel Island Crew
Channel Island Crew
Wed Apr 07, 2010 4:57 pm
its rather strange.
Thinking we may have got something we shoudn't have got wet, whilst sorting out coolant. The coil is dry tthough, which is good!
SteSE
Wed Apr 07, 2010 5:00 pm
Are you getting a spark from the coil lead?
ETA Watch it don't belt ya too :twisted:
87.5 Impact FM
PS3: gary_bunter
Nay
Channel Island Crew
Channel Island Crew
Wed Apr 07, 2010 5:17 pm
i will double check, but how do i properly check?
Is the crank sensor the little lead that sits at the top of the crank pulley?
dickster
Wed Apr 07, 2010 5:29 pm
Nay wrote:i will double check, but how do i properly check?
On the later ones it is but I thought you had the earlier engine and box or did they keep the original later gearbox/TDC sensor on the crank pulley and just fit the earlier block/head and cooling system?
Check for a spark then report back.
1988 325i Sport
SteSE
Wed Apr 07, 2010 5:35 pm
Just follow the lead from the coil to the dizzy, pull out the lead at the dizzy end and rest it somewhere in the bay. Get someone to crank the engine and see if it's sparking.
Not sure where the crank sensor is as my car is the oldder style with pulse sender. i think it works off a trigger wheel but where this is located i'm not sure - not near any of the cars to check. You should also have an extra HT style lead and i think goes to the coil to dizzy lead.
That might also cause this issue but i'm not sure what it does - would be interested to know.
As you've replaced all HT leads and plugs, if you've still got the old ones it might be worth trying them again just incase.
87.5 Impact FM
PS3: gary_bunter
SteSE
Wed Apr 07, 2010 5:37 pm
I thought he had later engine :o: what type of engine do you have Nay?
87.5 Impact FM
PS3: gary_bunter
Nay
Channel Island Crew
Channel Island Crew
Thu Apr 08, 2010 3:52 am
I haven't replaced the leads.... but I can nab any of them from my 320i to test if that is needed. Providing they're compatible, which I'd think they are.
I thought he had later engine what type of engine do you have Nay?
Urm, difficult to say really. It was bought as a project car from day one, and the guy I bought it from said it had the earlier HC engine, in a facelift shell. The cooling system is from the earlier type and after that, I can't tell the difference.
I want to fit the later Motronic at some point, and the later cooling system.
biggee
Thu Apr 08, 2010 1:04 pm
OK, daft question but where is the battery located?
Nay
Channel Island Crew
Channel Island Crew
Thu Apr 08, 2010 4:24 pm
@biggee - boot mate. 325i tintop.
Right, tested with the coil and ht lead from my 320i to no provail. could it be a fried ecu? hhhheeeeellllppp!!!!!!!!!!!!!!!!!! :cry:
ross_jsy
Thu Apr 08, 2010 4:29 pm
Try testing the crank sensor? I am sure mr moore will be able to help with that.
What codes your ecu? I shall have a look at what mine is, you never know. Yours may have the later injection system all there.
Nay
Channel Island Crew
Channel Island Crew
Thu Apr 08, 2010 5:21 pm
ok, will need more info on the crank sensor.
ecu box says motronic (stamped into it), and has a bosch sticker on it. the codes on the sticker are:
0 261 200 073
1 289 786.9
there is also a circled number saying 078
zaust
Zone day release
Thu Apr 08, 2010 5:31 pm
First thing you need to check is the DME relay. Most likley stuck in one position. Located under the cover by the AFM. The orange one is the fuel so leave alone.
If this is not the cause then, The 073 ecu's suffer with dry joint's. Either try a known working one or open yours up and look for the yellow brown bit's round some of the joint's on the tracks and resolder.
If it is your crank sensors(yes 2) are located near the starter motor and the go into the gearbox to read off of the fly wheel. If these are down they are about 90 each :o
M30 Tech 1 Touring on gas.
Nay
Channel Island Crew
Channel Island Crew
Thu Apr 08, 2010 5:49 pm
zaust, whats this dme thing?
**BANNED**
Thu Apr 08, 2010 6:27 pm
Are the plugs getting wet when you crank the engine?
Youth is wasted on the young.
zaust
Zone day release
Thu Apr 08, 2010 7:00 pm
The Digital Motor Electronics (DME) relay unit is a double-relay-in-one box. The main relay is used to fire the DME control unit (ECU), while the second relay gives power to the fuel pump. Failure in the injection system is usually down to the DME relay. So Change it first. Either blue or white and located under the cover next to the Air flow meter.
dickster
Thu Apr 08, 2010 7:43 pm
I think first of all you need to find out exactly what you have i.e whether whoever fitted the earlier engine fitted the earlier injection system or not, if it has the later system then you're laughing because certain bits like the crank sensor will be the same as your 320i so you can swap stuff to test it but if its the earlier system then it'll be different, obviously the ECU is different but I wouldn't jump to conclusions yet.
Again are you getting a spark or not? you say you've swapped the leads and coil but not actually said if you're getting a spark or not and thats quite important.
1988 325i Sport
ross_jsy
Thu Apr 08, 2010 11:27 pm
Anyone know if you can swap the ecu out with a facelift even with preface electrics?
Nay
Channel Island Crew
Channel Island Crew
Fri Apr 09, 2010 4:02 am
Uncle Malcom wrote:Are the plugs getting wet when you crank the engine?
Urm, I noticed bubbling in the one on the coil (although the coil has always been bone dry...), and I really should check them all. What does this mean? I thought that could have been water damage, so tried other leads to no provail.
Richard wrote:I think first of all you need to find out exactly what you have
So true. By the looks of it, plenty is different from the 320i, so assuming that almost all of it is prefacelift.
Richard wrote:Again are you getting a spark or not?
I dont think I am. Can't physically see anything, but the coil did electrocute my dad (through a spark plug we were trying to test) as I turned the ignition off. So electricity is lurking around. Spark, not too sure, but I think not.
Nay
Channel Island Crew
Channel Island Crew
Fri Apr 09, 2010 11:46 am
Anyone got anymore ideas?
Nay
Channel Island Crew
Channel Island Crew
Fri Apr 09, 2010 12:38 pm
zaust wrote:The Digital Motor Electronics (DME) relay unit is a double-relay-in-one box. The main relay is used to fire the DME control unit (ECU), while the second relay gives power to the fuel pump. Failure in the injection system is usually down to the DME relay. So Change it first. Either blue or white and located under the cover next to the Air flow meter.
I have this thing that has two blue cubes (look like the cubes found in the fuse box), right near the AFM. Is that the DME as I have no idea. There isn't anything like an orange one.... oh and would I pull the little bluish cover off the cube to check the connections?
biggee
Fri Apr 09, 2010 1:04 pm
Nay, I went through all this S**T recently, have you checked to see if there is an inline fuse on the thin wire coming off the + battery lead in the boot, its about 18" along under a plastic sheath, its a 50 amp fuse, my had a very fine break in it which caused intermitent starting and cutting out, even if it looks fine it might be an idea to bridge it and crank it over. Let me know how it goes.
Nay
Channel Island Crew
Channel Island Crew
Fri Apr 09, 2010 1:27 pm
Bridge it? as in bypass the fuse for a test? I'll try when I get to the garage in a bit.
biggee
Fri Apr 09, 2010 2:33 pm
Yes, there are two little holes either side of the fuse so a reasonalble bit of thick wire will slot in them.
Nay
Channel Island Crew
Channel Island Crew
Fri Apr 09, 2010 9:50 pm
Fuse is fine.
Relays (all are fine).
After a check, 100% not sparking. Only thing I can think of is the ECU itself... or the crank sensors, but I wouldn't know how to check them!
As I said, its not the coil, the HT leads, or the fuses/relays...
Any more suggestions?
Whats the compatibility between pre and post facelift ECUs? I take it none.
Whats involved in swapping round the whole management system, if need be...
zaust
Zone day release
Fri Apr 09, 2010 10:14 pm
There is no compatibility between them, To check the sensors you will need a meter and see what ohm's they are reading. Post your findings.(not in an envelope)
Nay
Channel Island Crew
Channel Island Crew
Fri Apr 09, 2010 10:17 pm
If we have a meter then I'll test it and uppy the results. Where would I put the meter to test?
zaust
Zone day release
Sat Apr 10, 2010 1:26 am
If you unplug the sensor, you will see the pin's that you need to prod. It should read 500-600 ohms iirc.
Nay
Channel Island Crew
Channel Island Crew
Sat Apr 10, 2010 3:20 am
I'll have a gander. Is it the two things near the back/middle of the crank case on the passenger side?
A fellow zoner has kindly offered to send me an ECU. If it works, send him a postcard! So, next week sometime, we can try that.
biggee
Sat Apr 10, 2010 1:51 pm
When you get your meter check the power at the far side of that fuse.
