poor idle when car is cold
k9
Post Fri Sep 02, 2005 11:55 pm
Any idea what could cause the car to idle poorly when cold?
My car dips from 650rpm - 400rpm and occasionally cuts out until its been run for 6-8 minutes and is warnish then it settles at 650rpm which is still a little low, any ideas why?
Also fuel economy is poor, 100 miles to Ԛ£20, my M535i used to do that and that was a 3.5 and heavier??
K
Templ8e30
Post Sat Sep 03, 2005 5:04 am
Could be 2 things,
The blue temperature sender on top of the thermostat housing can go duff (had this on a 320i, ran rich and was a pig to start).
The idle control valve may be blocked or faulty. Try cleaning the innards with lots of carb cleaner. Has been known to work.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
