It also does this when turning around corners... I have been told that it could be a bearing..? how can you tell which wheel could this be??
Knocking noise
I have knocking noise coming while driving, it gets louder as speed increases what can this be..?
- Paul325ITouring
Hi it could be a the diff m8 is the noise more from the back? I had the same and it was a worn diff, try jacking up the car and spining, each wheel.
A duff wheel bearing wont give a knocking noise, more of a rumble. The rumble can get more noticeable whilst turning.
You may be able to hear it if you jack up each wheel and turn by hand or pull the wheel top and bottom to find any play in the bearing.
When is the MOT due - if a wheel bearing is shot, the tester should pick it up.
If its a knocking noise that gets louder with more speed, Id get the prop centre bearing checked.
James
'91 325i Sport
'93 318i touring 16v
'91 325i Sport
Not really.
Wheel bearing (front) can be had for £30-£50 plus fitting - should be no more than hour at a decent garage. Rear bearings are cheaper to buy, but can be more difficult to fit.
Prop centre bearings are around £20-£30 -again an hour should do it.
Unless the diff has been run low on oil or abused a lot, I doubt it will give much of a problem. Most knocking noises associated with diffs are down to a knackered diff mount bush.
Even if the diff is knackered, an open diff will be easy to find and usually cheap as everyone wants the LSDs.
Can you describe the noise better?
Is it a knocking or rumbling? Does it happen all the time whilst on the move or just a single knock every now and again (when turning for example)?
James
'91 325i Sport
'91 325i Sport
Could be a wheel bearing, more than likely a front one. Should be no more than £100 all in for a garage to do it and thats with a quality bearing.Tripper wrote:Sometimes driving along I dont hear anything, when the speed is up 40mph+ the rumbling gets louder.. louder when driving round corners...
If youve got access to a 36mm (IIRC) socket, a torque wrench and a decent hub puller, you should be able to DIY it.
Loose wheel nuts could also be an issue.
James
'91 325i Sport
'91 325i Sport
I feel like loose wheel nuts sounds more like a "flat tire" and you feel it on the steering, but it would be a good idea just to check. Has happen to me 2 times, first time it took a while before i knew what it was, just cached it in time.
