Gear Box Oil
Stealth
Post Thu Sep 01, 2005 8:29 pm
Hi, Any help on changing the Gearbox oil on my 88' 325i CAB would be greatly appriciated..!! Sounds a bit noisey.>!
Toby_Unna
Boost Junkie
Post Fri Sep 02, 2005 9:07 am
changing the box oil probably won't quieten it down.
but anyway... there's two plugs on the right-hand side of the box, you need either 17mm spanner or a large hex-drive socket to fit them. the higher one is the fill plug, the lower one is the drain plug.
they may be very very tight, if they seem immoveable don't risk using a huge bar and breaking the gearbox casing!
if they come out ok remove the fill plug, then the drain plug.
not entirely sure how you're supposed to put new oil in with the box in the car though! i've only ever filled boxes before installing them.
Post Fri Sep 02, 2005 9:58 am
Remove filler plug before the drain plug!
If you drain the oil first, and then can't unscrew the filler you are bu**ered.
Toby_Unna
Boost Junkie
Post Fri Sep 02, 2005 1:45 pm
Toby_Unna wrote:remove the fill plug, then the drain plug.
Brian how do you get the oil into the box? a tube and a pump? never had to do this
Fushion_Julz
Post Fri Sep 02, 2005 3:03 pm
2 methods of filling the box....
1. (the simple, but slow one) fill a small oil can with a pump action...insert the end in the fill hole and pump
2. (the fast, but more involved way) remove the gearstick gaiter, the foam surround and poke a 1/4" or 1/2" plastic tube down the gap between the gearstick hole in the transmission tunnel and the gearbox...put the underneath end in the fill hole and put a funnel in the in-car end...Carefully fill from above
1987 Henna Rot M3 (was 195bhp CAT..now more and no cat)
2001 E46 330i SE Touring (manual)
Post Fri Sep 02, 2005 4:06 pm
The oil usually comes in bottles with a plastic tube extension on them.
Bend the tube 2" from the end, stick it in the filler hole, and roll the bottle up. Keep going untill you get an eyefull of oil. Helps if you warm the oil first.
You can only get about half the bottles in, so I empty half empty ones into other half empty ones.
