Hey everyone, the engine in my 1990 318i auto needs replaced and was wondering if a 1993 518i m40 engine with a manual box would go into my 318i auto without any problems ?
thanks in advance guys
1993 518I M40 ENGINE WITH MANUAL BOX INTO A 1990 318I AUTO
- **BANNED**
At a guess the sump would require swapping,not too sure if the E34 gearbox would be an easy fit,but an E30 type is cheap enough s/h.
Be a few bits to sort out regarding the autobox electrics,but nothing too major.
Youth is wasted on the young.
- Brian28
- Contact:
Just the engine will be more or less a straight swap. Use all of the bolt on bits from your old engine, including the auto flywheel. Its very likely that both bits of the sump and oil pick up pipe (you will see it when you take the sump off) will have to be swapped over as well if the 518 has the oil pan behind the crossmember like the E36 does, but its only ten minutes to do.
