Drivers side lock: unlocks but doesnt lock....
takamichinoko
Post Fri Mar 19, 2010 1:06 pm
Hi,
Had the problem for so long but its just getting anoying now.
I replaced every lock on the car when i bought it cos all of them had been tampered!
Anyhow, i have to lock the car from the passenger side. drivers side opens but drivers side just turns and engages nothing when you try and lock it. Ive had a really good look inside but cant really see whats wrong?!
Anyone have a diagram or any advise?
lawriejones
Post Thu Apr 29, 2010 9:40 pm
Check the driver door actuator is in place and connected to the metal link.
it should be fitted to the door panel by 2 screws.
alync205
Post Thu Apr 29, 2010 11:40 pm
I would say it could be you door lock(barrel) that is at fault.The bit you put the key into.On the drivers side it has a dead-lock mechanism and this bit in the lock can break then it wont turn enough to lock the car.
gra325i
Post Thu Apr 29, 2010 11:45 pm
or it could just need copious amounts of WD40 or the likes sprayed in there...worked for me :wink:
