Clio brake Servo swap
325zimmer
Thu Mar 11, 2010 6:18 pm
Hi guys.
Can anyone help, i need to change my servo and i'm wondering whether to change it for a clio one.
So is the Clio brake servo and a standard 325 master cylinder a straight swap? Or do you need to do any mods to get it working?
Thu Mar 11, 2010 6:22 pm
the E30 master cylinder bolts straight to the clio servo,but you will more than likely need to insert a small space into the end of the master cylinder rod so that there is no slack on the pedal. It will all become obvious once you have the servo and master cylinder in your hands
Thu Mar 11, 2010 11:54 pm
The Clio servo is not an 'upgrade' in any way. It's just one of the methods used to make more room in the engine bay when fitting certain different engines.
