auto flywheel and manual flywheel
JasonR
Wed Mar 10, 2010 12:43 pm
Hi, does the automatic 325i have the same as the manual? thanks.
town325i
Wed Mar 10, 2010 1:21 pm
No they are totaly different as the automatic uses a tourqe converter and a seperate starter ring bolted on in place of a flywheel
Wed Mar 10, 2010 1:25 pm
If you're thinking of fitting an auto engine to a manual gearbox; less obviously, the auto engine doesn't have a spigot bearing in the crank in the middle of the flywheel. Just needs to be fitted.
