Oil Change hELP m42
jon-m42
Tue Mar 09, 2010 1:59 am
Engine oil rite guys I have my 1.8IS m42 engine with 178k on the clock and still going strong. Time has come for a oil change.
At present and for the past couple oil services I have been using GTX Castrol Magnatec 10w 40 engine oil I have had no problems with this oil at all runs smooth every time all the time seems to burn a little quick on allot of motorway driving but that’s like most I guess.
http://www.getprice.com.au/images/uploa ... 0_1733.jpg
After doing some reading and asking around other fellow enthusiasts they recommend using Mobil as it apparently is a better oil and a bigger company so i have been told, they recommended me to use Mobil Super S 10w 40 semi-synthetic (very high performance)?
http://www.nielsencdg.co.uk/acatalog/MO ... 18x500.jpg
Has anyone had any good feedback using this oil and pros or cons.... or shall I just stick and stay with what I have been using.
Many thanks to all in advanced.
Jon-m42 :)
Kos
Tue Mar 09, 2010 2:13 am
i'd only ever use fully synthetic
have look at opie oils website for some information, but be prepared to be head fucked.
www.pukardesigns.com
IG Pukar.Designs
jon-m42
Tue Mar 09, 2010 1:15 pm
any1 else thanks kos i will check them out as soon as 8)
jon-m42
Tue Mar 09, 2010 5:21 pm
http://www.opieoils.co.uk/product-finde ... der-2.aspx
i have gone on the website and now am not sure which one to go for as non of them listed are 10w - 40 :? have i been using the wrong grade all this time ?
regards
jon-m42
Sat Mar 13, 2010 8:02 pm
Anybody applogies if i am annoying im just puzzelled :mad:
alync205
Sat Mar 13, 2010 11:34 pm
I always use 10W40 oil in mine,was using castrol magnetec in it before but have total oil in it now.My car does burn a little bit of oil too.If you put in a lighter oil like 5W40 or 0W30 I would expect it to burn alot more oil.I recon that you would be better off sticking with 10W40 oil,that is what is listed for the 318iS on autodata anyway.
Kos
Sun Mar 14, 2010 2:18 am
wrong,
a 5w40 is no lighter than a 10w40 at opperating temp. some engines use bit of oil as its in their nature to do so, some do it because its a tired engine. some do it because its shit oil.
10w40 is about right for this country and that engine, and a fully synthetic one. a 5W will help it warm up quicker, thats about it.
the only advise i'll give though is to use fully sythetic oil that will not break down
the questions is jon, how do you use your car, just commute, do you gove it some stick, do you do track days with it ?
IG Pukar.Designs
jon-m42
Tue Mar 16, 2010 12:34 pm
Thanks to the both of you
kos I use my car mostly motorway driving and allot or town in a week I manage to do about 400 to 500 miles most of which is on the motorway.
Motorway speeds are 70mph to 80mph all the time no more than this at all and to be fairly honest extremely rarely I put my foot down on a clear stretch on the Motorway when I get the urge to do so she haply climbs to 130mph but never more than this as I run out of road and more importantly its a old engine with close to 180k on the clock.
all this driving has been done using GTX Castrol Magnatec 10w 40 engine oil.
Hope this helps Kos
Regards
Jon
:wink:
Saga
Tue Mar 16, 2010 1:50 pm
Just thought I'd point out that your owner's manual has a chart which clearly sets out what grades BMW _originally_ intended (with 198x oil technologies) the engine to use in which temperature environments. IIRC, UK summer & autumn temps fall in the 15w40 range for the 4-bangers, and 10w40 in our normal spring & winter temps (Dec - April).
As for which oil is best, that's a subject with a lot of opinion and little or no relevant data. IMO, use an oil with the appropriate API rating or higher and change at the specified intervals.
Mineral and blended oils will have less shear resistance etc., so you will not want to run them any longer than factory intervals. Fully synthetic may allow you to extend oil change intervals without additional wear, but to do so safely you need to do an oil analysis at your next oil change to determine wear metal content and oil performance, then continued analysis with a fully synthetic fill (and you're flushing the sump out, right?) at and after the recommended change interval to determine just when it actually starts to degrade in your motor.
e: equally, film strength should be higher with a top-quality modern synthetic, meaning you may in theory be able to run a less viscous (easier-flowing) oil to get superior cold-start protection etc etc - but to test this theory you need to pick the right weight and then test as above, which will cost you a packet and be a PITA. With the later sixes, you have the advantage of at least being able to see if the oil is BMW LL01 (LL04 for the newer cars?) approved, but for the M42 you are SOL.
If your motor burns oil and burns different amounts in different conditions, this is going to be tough to do (i.e., nearly pointless), as you can basically be replacing the entire sump capacity between filter changes and will not have a baseline figure for any oil you use.
Kos wrote:wrong,
jon-m42
Thu Mar 18, 2010 5:50 pm
what oil do i use then guys? and where do i got to get it ? :mad:
regards
jon
