diff question
lesward
Mon Mar 08, 2010 8:19 pm
is there a easy way of telling if one has a lsd? there a 4 diffs at a friends and none of us know if they have a lsd?
DHFiS
Mon Mar 08, 2010 8:28 pm
To be 100% sure the best way is to take the cast aluminium plate off and look at whats inside.
scottidog
Mon Mar 08, 2010 8:32 pm
turn one side of it and see if the other side spins the same way!!! If so its an lsd. If spins opposite its not!!!
You win some, You loose alot!!!
bimanut
Mon Mar 08, 2010 8:35 pm
Another way is to turn one of the outputs and if they both turn the same way then it should be a lsd.If they turn in opposite directions then its an open diff.
mrLEE30
Tue Mar 09, 2010 6:11 am
DHFiS wrote:To be 100% sure the best way is to take the cast aluminium plate off and look at whats inside.
only REAL way is to open and look for the clutches. the two other options above will also work for a welded diff.
failing that look at the diff tag, an LSD will have an S in the tag before of after the ratio.
lesward
Tue Mar 09, 2010 10:06 am
thanks will look at tags for s and try the methods the guys have put up cant see any wleding on diffs
what are lsd,s worth?
jmc330i
Tue Mar 09, 2010 11:57 am
lesward wrote:cant see any wleding on diffs
You will only see the weld once you have removed the backplate - the gears inside are welded together.
If you remove the backplate, you will be able to see the clutches anyway (or not).
James
'91 325i Sport
'93 318i touring 16v
lesward
Tue Mar 09, 2010 2:25 pm
ok so if clutches they are lsd?
Torsen
Tue Mar 09, 2010 8:06 pm
This is what a LSD looks like after removing the plate:
lesward
Wed Mar 10, 2010 5:56 pm
any body got pic of standard one so i can compare? and what are they worth?
gareth
Thu Mar 11, 2010 1:03 am
the holes you can see in the 'spool' are huge in an open diff and you can see the gears inside. eg, if it looks different to that pic, it's not a LSD :D
lesward
Thu Mar 11, 2010 9:22 am
ok thanks will look this weekend
