Post
Thu Sep 01, 2005 1:32 pm
the stat for the oil cooler is on the housing anyways so no need to budget for that Alex, as for the stock unit, mines upside down @ an angle accross the rear of my IC, its a squeeze butcan be persuaded to fit, if you find the hosing clashing you can cut and shut the steel sections @ the block end to improove the situation
Email FTW
