The symptoms are that it would overheat if you let it, the top hose stays cold, the heater doesn't work and it pressurizes the coolant.
It's got a known good 'head on it and has a brand new head gasket, water pump and viscous coupling.
It starts fine from cold, but if you switch it off and then go to re-start, it struggles to compress what's presumably water in one of the cylinders, then spins over and fires.
Sound terminal to anyone else?
