Swapping to 51mm struts
ollie_
Sat Mar 06, 2010 10:32 am
Morning all.
For the suspension i want to use on my 318i i need to swap to 51mm struts.
now... do i need to swap all the brake bits, bearings, and gubbins off my struts onto the new struts,
or can i just disconnect the lines and swap over the whole hub assembly, brakes and everything?
The latter would obviously make life a bit easier, but just want to make sure it'll work, with regards to brake system coping etc...
Also, is it something i'm gonna be able to do in a couple of hours on the pavement? pretty handy with a spanner when i want to be, so it'll just be bolt off bolt on i presume?
Any other hints or tips, hit me up :)
Ta! Ollie
Sat Mar 06, 2010 11:03 am
Hubs don't come off without damage, so you're stuck with either new ones or the ones that are on the strut now.
Everything just swaps over complete - everything fits exactly the same. You obviously can't fit your existing calipers onto the new discs if they are vented ones, as they're not wide enough, but the complete assembly can be swapped over.
ollie_
Sat Mar 06, 2010 1:00 pm
sorry when i said hub assembly i meant the whole strut and everything lol,so the units will just swap no problem?excellent :)
Sat Mar 06, 2010 3:24 pm
if you go 51 mm i'd fit the vented discs and the suited callipers.two birds with one stone :D
the difference between 45mm and 51mm is the girth of the insert damper.
the bigger the better!
ollie_
Sat Mar 06, 2010 3:36 pm
will the master cylinder and servo thats in at the moment cope with the bigger calipers if i do decided to uprate discs etc?
Sat Mar 06, 2010 3:46 pm
the master cyl and servo are all the same gutswise.
these are 51mm legs.all tourings have them as do cabs,325i's and the humble 318is.
only the is has the correct springs for a 4-pot on 51mm legs.you coul use your springs but i'd buy the set of is springs that are in the for sale section atm
Sat Mar 06, 2010 3:50 pm
these are what i'd buy unless you want to spend coinage.
http://www.e30zone.net/modules.php?name ... c&t=161308
ollie_
Sat Mar 06, 2010 3:56 pm
fantastic, cheers man :) like i say i'm changing the shocks and springs already, getting adjustable top mounts for camber, and now just need the whole strut setup which i have access to a set of!!
thanks for the advice man, very helpful :)
jmc330i
Sat Mar 06, 2010 3:59 pm
magpie wrote:all tourings have them
Not all.
The 318i touring had 45mm struts up to Sept 89, after that they were 51mm.
James
'91 325i Sport
'93 318i touring 16v
Sat Mar 06, 2010 4:01 pm
BRIAN ??????????????????????
this is news to me. :?
jmc330i
Sat Mar 06, 2010 4:11 pm
100% - confirmed by the VIN of my touring by BMW.
I had hassle getting shocks for it cause I ordered by the reg number. 45mms turned up, I sent them back as I thought they should of been 51mms.
51mms turned up, I tired to fit them and thought some bugger had swapped the struts for 45s. A phone call later to BMW with the VIN confirmed it had 45mm from factory.
Check the ETK/Realoem, Click Me....
If the link works, just hit the browse parts button and go find the shocks.
James
'91 325i Sport
Sat Mar 06, 2010 4:19 pm
jmc330i wrote:100% - confirmed by the VIN of my touring by BMW.
dude this info is valued.
i don't want to sell 47mm as 51mm.
did yours have vented discs?
jmc330i
Sat Mar 06, 2010 4:38 pm
Yup, vented discs up front.
I actually used the calipers on my Sport when one of them decided to seize up (I swapped both as the touring had Girlings and the Sport ATE).
James
'91 325i Sport
Sat Mar 06, 2010 4:41 pm
another lesson in e30 world learned 8)
Sat Mar 06, 2010 8:44 pm
Yes, very early 318 tourings had the smaller front legs, but I've never come across one. Diesel tourings alledgedly have them as well.
Vinevo
Sat Mar 06, 2010 11:47 pm
I have a 318 Touring, first registration 01 10 89, according to GSF and BMW using reg. and Realoem using VIN I should have 51mm struts-so that is what I ordered. But yesterday when I went to fit them at a mates garage we discover that I have 45mm struts! Am in the process of sourcing 51mm legs to fit but now think after reading this that they are currently correct at 45mm. Not sure what to do now, get 51 legs or return shocks for smaller 45 ones!? :?
jmc330i
Sun Mar 07, 2010 12:10 am
Vinevo wrote:I have a 318 Touring, first registration 01 10 89, according to GSF and BMW using reg. and Realoem using VIN I should have 51mm struts
It should be on the build date and as yours was registered 1/10/89 it could of been built as an 'early' one.
Well a 51mm strut will be an upgrade and as you already have the shocks, if you can find the struts it wont do any harm changing to them.
James
'91 325i Sport
leeparkes
Sun Mar 07, 2010 12:14 am
Are 'all' 318 IS fitted with 51mm struts?
Im about to purchase some fully rebuilt one's and im hoping there 51mm
jmc330i
Sun Mar 07, 2010 12:17 am
Im sure all 318iS's had 51mm struts - I havent seen any info to suggest otherwise.
James
'91 325i Sport
Sun Mar 07, 2010 12:18 am
leeparkes wrote:Are 'all' 318 IS fitted with 51mm struts?
No, I have one with the smaller legs, although I'm certain it left the factory with 51mm ones!
leeparkes
Sun Mar 07, 2010 12:24 am
To check is it the outer diameter of the strut housing you measure or is it the shocks that are 51mm?
jmc330i
Thats the problem, the info is out there to find out what it should have fitted etc, but you dont know whats been changed in the last 20 odd years.
James
'91 325i Sport
Sun Mar 07, 2010 12:28 am
leeparkes wrote:To check is it the outer diameter of the strut housing you measure or is it the shocks that are 51mm?
Outer diameter of the strut tube.
leeparkes
Sun Mar 07, 2010 12:30 am
Thank you.
bigredbmw
Zone Supporter
Sun Mar 07, 2010 1:29 am
i am changing mine to 51mm struts tomorrow with all the 325 brakes as am changing rear beam next month as well
Sun Mar 07, 2010 12:22 pm
what yr is yours Brian 90 or 91.?
Sun Mar 07, 2010 12:41 pm
On an 'H' plate, but it has 'aquired' the 42mm legs somewhere along the way.
Sun Mar 07, 2010 1:03 pm
Brianmoooore wrote:On an 'H' plate, but it has 'aquired' the 42mm legs somewhere along the way.
you kept that one quiet.
i bet you only bought it to look at the harness.
light chuckle to myself :o:
Sun Mar 07, 2010 2:27 pm
Main reason I bought it, other than to have one example of a (baby) M3 in my collection, was that it had absolutely immaculate (as in 'must be new replacements') front seats.
Sun Mar 07, 2010 2:45 pm
dark check?
Sun Mar 07, 2010 2:57 pm
Haven't got them in front of me, but they're check of some description.
Sun Mar 07, 2010 4:38 pm
Brianmoooore wrote:Haven't got them in front of me, but they're check of some description.
black vynal<? sides on the seats or black head liner go together.
what colour is the car.sorry to nit pic.
Sun Mar 07, 2010 5:00 pm
Car is red, head liner is (was) white. No idea if the sides are black vinyl.
