323 motronic
dazleeds
old skool raver
old skool raver
Post Mon Aug 29, 2005 6:16 pm
as above how do i do it??
have all the bits from a 320ise h plate can they be used to make my spare 323 engine run motronic??
if i can then its off into mine for a while :cool:
all info welcome
what to swap??
how to do it??
any awkward sheeite??
cheers all
www.oldskoolfantasy.co.uk
Ant
Retired Team Member
Retired Team Member
Post Mon Aug 29, 2005 7:05 pm
use the front timing cover and bottom pulley/crank sensor arrangement
,use the 2.0 intake and injectors too but a 2.5 would be better for flow
basically all the loom and sensors from the motronic need swoping to the B23 and she'll need a chip to suit, 2.5 a tad too much fuel, 2.0 opposite, I have done a 2.3 variation for a guy in NZ, all reports suggest she kicks arse, the b23 is the true screamer m20
HTH
dazleeds
old skool raver
old skool raver
Post Mon Aug 29, 2005 7:12 pm
helps loads mate cheers
most people instantly tell me dnt bother get a 325 but iv been there done that and besides i dnt like waste and everything i should need is sat here on the drive
good to hear someone agreeing with the 23 for once
have had a 100+plus mile drive in the 323 and engine was so smooth and lot faster than my 320 so seems the obvious and cheapest shorterm solution for me
cheers ant
anything else you can suggest to up its power driveability most welcome
ps can you do me the same chip you mentioned if i do this conversoin?
and what ecu will it go in?320i?
cheers :thumb: :cheers:
Ant
Retired Team Member
Retired Team Member
Post Mon Aug 29, 2005 8:26 pm
Daz, do the swop and get her running on motronic using the 320 ECU, dont cane it though and you must not use the jetronic injectors are they are the wrong impedance,
motronic with motronic always and you'll not go wrong, and as for the chip, no worries dude, can do that NP @ all
astondg
Post Tue Aug 30, 2005 12:59 am
ant wrote:I have done a 2.3 variation for a guy in NZ, all reports suggest she kicks arse, the b23 is the true screamer m20
There is only one 2.3L M20 right? What else was done to it? My 2.3L definately doesn't kick arse, but I'd like it to. I already have exhaust, no afm, and ems.
dazleeds wrote:good to hear someone agreeing with the 23 for once
I can't imagine a 320 being much slower than my 323i or any rougher. Mine rattles and taps and feels like it's working hard just to get to the redline. When I turn on the air-conditioning it sounds like a truck. The mechanic keeps telling me how clean and good it looks inside the engine and how well it's running. I'm starting to wonder if it is a 2.3L or if you guys got some special version :lol: . Maybe they like the climate in the UK better :D .
Aston
BMW E30 323i with some stuff
1:21.67 @ Morgan Park Raceway
