fitting a/c to an m40?
jonb
anyone done this? help needed!
Toby_Unna
- Boost Junkie
can't help u specifically jon, sorry to clutter ur thread
but i removed 2 systems recently one from a m20 and one from an m10, and the comp-engine mounts were totally different. and the bracket could not be swapped between compressors so different compressor for different engine
could do with knowing if my m10 compressor will fit an m40 or other engine by swapping the bracket - it don't go on my m30 and who wants to fit airon to an m10?
smithy318i
I have heard that it is more trouble than it's worth to retro-fit air con. It would be easier and cheaper to buy a car with it already fitted as standard.
A1BMW325iSport
diff rad and pump bracket is needed to fit to M40
Toby_Unna
- Boost Junkie
3 hours to completely remove everything from the donor carsmithy318i wrote:I have heard that it is more trouble than it's worth to retro-fit air con. It would be easier and cheaper to buy a car with it already fitted as standard.
so realistically 1 day to reinstall
plenty people have done it. and compared to the time iv spent on my car 1 day is nothing
jonb
toby
that clears it up! thanks dude.
i just sold a 2,5 a.c settup to someone with an m40. so im sort of getting a headache hearing this.
and your right. it takes a while to remove.
Toby_Unna
- Boost Junkie
jon (or anyone!)
i'm assuming all m20 blocks would use the same compressor mount points (i.e. early or late, 2.0 or 2.5). anyone know if this is the case, or if there's external diffferences between blocks.
if not i'm going to be getting a similar headache to you jon
on a separate subject, on the offchance that an m10 compressor uses the same mounts as an m40, i have one available. can get u pics of mount points if u interested
