can any one help cant rev over 3000rpm
http://cgi.ebay.com/ebaymotors/OEM-BMW- ... ccessories
this is it,its on your throttle body,you can see in pic that its got slotted holes for adjustment,you need to be good with a multimeter to adjust it,check if yours is loose,if not its probably faulty,im sure theres loads of people on here that'll send you one for cheap,try whipsey
gareth
can you get a picture up?
it sounds like it could be the AFM (airflow meter) plug. in which case, it wouldn't run very well at all!
my first port of call would be to check all the inlet hoses for cracks / splits.
