What is this wire?
- Japandrew73
- Contact:
On the accessory wiring harness coming from the fusebox that has your headlight wires, foglight wires, washer wiring, etc., when you get to the connector for the power to the washer system which is a purple power and a brown ground, bundles with it is a black with white stripped wire that goes to a little one pin connector. What the hell does this wire do?
Hopefully this was better of a description.
If not I can take a picture tomorrow.
I tried tracing the black with white striped wire back to the fusebox but it doesn't go all the way.
EDIT:
Found a really old picture! It looks like it connects to two blue wires wires with black stripes. Anybody got a clue? I checked both my m10 and m30 wiring engine wiring harnesses too and didn't see two blue wired with a square connector at the end.
http://i87.photobucket.com/albums/k146/ ... GP0038.jpg
EDIT:
- Japandrew73
- Contact:
town325i wrote:headlight wash control?
sorted the pic
Phase I - Bodywork Complete
http://www.e30zone.net/modules.php?name ... by+restore
Phase II - 2.8 stroker- Complete
Project II - 325 Motorsport Cabriolet Restoration.
- Japandrew73
- Contact:
It looks similar to the maplight mirror plug, but it's not. My car was povo spec meaning it was a base model. I had to retrofit my maplight.zaust wrote:I can't see the pic as i'm on a work pc, but from your discription and iirc this is the wire for the map light mirror. Have you done a power test to see if and when it goes live.
- Japandrew73
- Contact:
Ignore the red wire, thats the PO's attempt to wire in city lights. The black/white wire goes through the square plug into two blue wires which I can't tell where they go because my car currently has no engine in it and the wiring harness is removed.DanThe wrote:Something to do with aircon possibly, what is the red wire? Where do the blue wires from the other side of the plug go?
- Japandrew73
- Contact:
bump
Cloggy Saint
- Brianmoooore
This is where heated washer jets plug in, (and headlamp wash/wipers) but this doesn't look like those looms.
The purple/black is a first ignition switch position switched, fused 12 volts + , and could be used by BMW for anything they chose.
I don't recognise any of these wires, in fact I've never seen a wire an an E30 with the secondary colour as rings rather than a stripe.
Where do the two blue wires go?
- Japandrew73
- Contact:
Ok I got my 84 318i engine wiring loom and found the wire in the picture. Here it is. It's off the same strand that goes to the coil, it just keeps going on to one blue wire that goes into the square connector. It can't be for the heated washer jets. What's it for??? (It's hard to see in the pic, but it's the far right connector)Brianmoooore wrote:This is where heated washer jets plug in, (and headlamp wash/wipers) but this doesn't look like those looms.
- Japandrew73
- Contact:
Yes I just checked one more time to verify. It's 2 Blue w/ black striped wired going into the square plug, then on the other plug that plugs into the blue/black plug is the black/white striped wire.willnz wrote:Is the wire colour definitely blue with a black stripe?
- Japandrew73
- Contact:
Very strange... well I appreciate your help nonetheless, thanks!willnz wrote:The only thing I can find in my wiring diagrams that utilises a blue/black wire in that vicinity is a relay that is energised by the A/C compressor to prevent the fuel shutoff on overrun.
Like Brian, I have not seen a candy-striped wire in an e30 before!! (black/white wire)
