Can any one help
boot shutting
millsy81
hi just noticed that my boot on my 325 has all of a sudden not shutting correctly one side is higher than the other is their any way of adjusting the hinges or an other way??
Can any one help
Can any one help
TW166Y
i just did mine mate the other day, was slightly out of line from one side to the other, i also thought it was the hinges but it is the loch itself, i think if i remember right i adjusted the boot lock a little (10mm) and did the same with the actual clip on the bootlid itself, once you have adjusted all correctly it will pull the boot lid back into line, if you need any more info give me a shout, cheers
Saying goodbye to 4-pot wrongness
Martinaston
Just screw the rubber stops in or out on the corners, that or the cars twisted
There is NO nucleus.
millsy81
Cheers fellas give it a go
