cutting out???
Karan
Post Sat Aug 27, 2005 9:01 pm
my tourer is having a slight cutting out issue... it just randomly jerks around a bit... i think it is fuel related.... could it be the pump? and how would i go about checking it if this is possible. most of the time its ok..... but just started a bit today after a hardcore drift shakedown session this afternoon with dave......
any thoughts (and spare 325 pumps) appreciated, as shes gonna be drifting on monday and last thing i need is pump failing,..,,
cheers
Karan
TOURINGDADDY
Post Sat Aug 27, 2005 9:08 pm
try the dme relay mine started tihs and that was at fault and i got 2 325 fuel pumps if needed
Karan
Post Sat Aug 27, 2005 9:12 pm
TOURINGDADDY wrote:try the dme relay mine started tihs and that was at fault and i got 2 325 fuel pumps if needed
yeh may be that whote relay...
i'll carry a spare on monday just in cae
where are u based richard?
TOURINGDADDY
Post Sat Aug 27, 2005 9:13 pm
portsmouth
fowler
Boost Junkie
Post Sat Aug 27, 2005 10:42 pm
i have fuel pump and DME relay if wanted
regards
Ben
Rich call me when you geta chance
Karan
Post Sun Aug 28, 2005 5:18 pm
car seems fine most of the time.....
however... it did it agian today for a bit... it seems as if it is fine on full throttle WOT but struggles everywhere else
i think it could be the AFM or ecu....
damn i need the car spot on tmro... i dont need cutting out
i opened afm and the trakkcs look spot on....
and i am getting a ecu of dave later this evening
i also noticed that one of the wires (green with purples stripe) going into the fuel pump relay had melted its sheath so i sorted that out.....could this have caused it
Karan
TOURINGDADDY
Post Sun Aug 28, 2005 5:44 pm
poss but i would keep close eye on it
fastcarz464
Post Mon Aug 29, 2005 8:26 pm
My car cuts out abit sometimes, i got told from a bmw specialist that its the connector block for the main engine loom and injector loom, he said if i cut off the connector and solder all the wires together i will have no more bad idle and cutting out issues,i did look at the connector and all the conctacts are very corroded, i clened it but still same although ailttle beter, just wondered if anyone else has done this?
