Clutch problem
H7AVY
Wed Feb 17, 2010 11:22 pm
How can you tell a clutch is gone. At present my i topped the fluid up and pumped the life out of the pedal to make it go hard but nothing it aint got no presure at all. Some help please guys.
Wed Feb 17, 2010 11:41 pm
If your clutch "has gone" you partially or totaly lose drive to the rear wheels, which I'm guessing is not the problem you have.
Your problem is most likely to be one with the clutch operating hydraulics.
Was the clutch fluid resevoir empty?
H7AVY
Thu Feb 18, 2010 10:09 pm
Yeh it was empty. Filled it up and nothing.
Thu Feb 18, 2010 10:25 pm
If it was empty, air will have got into the system, and it won't have a hope of working until the air is bled out!
This will be a pointless exercise , however, until you find where the original fluid leaked out.
pimpmobil
Mon Feb 22, 2010 6:02 pm
My fluid was always runing out. The problem was my clutch master cylinder was f##t. This is located by the cluch peddle. Got a new one, filled up fluid & had to bleed out the air from the cylinder located on the gearbox.
