325 advise needed
scottyc
Sat Feb 13, 2010 8:33 pm
hi there im doing a engine swap from a 316 to a 325 engine! but i need some help ! i have a few questions!
1- were does the servo pipe go? as it comes of the servo but cant find were it connects to?
2- which order do the leads go from the top of the dizzy cap? and which one does the king lead connect to on the dizzy cap?
3- on the pipe that goes from the throttle body to the maf, on the side (nearist the bulk head) theres a outlet for a hose to connect to! what hose?
4- the fuel lines, which way round do they go? i take it they go
fuel filter to rail / return to pressure regulator ?
5- as mine was a 316, i need to get a diffrent radiator and expansion bottle, but i only seem to have one heater matrix hose, does the other one come from the expansion bottle?
maxfield
Sat Feb 13, 2010 8:44 pm
From memory the pipe goes next to the TB.
2 - Don't know.
3. Sure it's not for the ICV?
4 - Yes.
5. Can't remember.
Sat Feb 13, 2010 8:48 pm
1. servo hose goes from servo to r/h side of TB
2. can't remember :mad:
3. ICV
4. yes :)
5. you will need the M20 rad and expansion tank, the heater matrix connects to the hose on the back of the head and the other to the hose that runs full length under the inlet
